carbon fiber arms question
deadpool66
Post by deadpool66 »
just ordered the trick laser arms. Have a quick question fo I need to adjust firmware values?
upgrading from the factory ballcup arms.
Re: carbon fiber arms question
If you install arms that are a different length than the factory arms, yes. Luckily, it's an EEPROM setting that you can change without much headache.
deadpool66
well I assume I would just adjust it out to 300mm but what about horizontal radius?
Post by Xenocrates »
deadpool66 wrote:well I assume I would just adjust it out to 300mm but what about horizontal radius?
That would be dependent on the carriages and carriage/joint interactions. I would try the original H-radius first, and then slowly adjust it as the V2 user manual specifies if that doesn't work. Unless you have an HE280 or similar, then just run the H-radius calibration, and it will do it for you.
