Upgraded the enclosure to separate the electronics from the build chamber.
https://goo.gl/photos/gFL5ouNLGBJDHswU6
https://goo.gl/photos/2GdVbgtMiXUsPJ876
Enclosure upgrade!
- barry99705
Enclosure upgrade!
Re: Enclosure upgrade!
I wonder how the extruder will do inside the chamber
- barry99705
It's been in there for over a year with no issues. The mount is printed in abs. I only print in petg, and the few times I've printed in pla it's been fine as well.
Glad to hear it. My enclosure is heated so I moved the extruder outside of the enclosure.
- barry99705
So far I've not really needed to add a heater. Depending on print time, it hovers around 80F inside.
ivanhandler
Looks great, do you have instructions on how to build one? Thanks
- barry99705
Not really. I took the dxf files for the printer and cut along the outside of the base for the hole. Then I just cut is square to fit the enclosure I already had.
