Enclosure for 7" Panel Due
DerStig
Post by DerStig »
I saw a enclosure for the 7" screen that fit in the Rostock Max V2 original LCD bay. It was also tilted. Anyone remember that one? I'm looking to print it.
Thanks
Re: Enclosure for 7" Panel Due
DC42 has one. He is the Duet and Due guy, after all.
http://www.thingiverse.com/thing:656884
DerStig
Post by DerStig »
That ones not it, I found it searching
http://forum.seemecnc.com/download/file.php?id=11783
crocky
Post by crocky »
It suits what I have in mind as well...
Looks like it must have the pcb mounted with a extension cable or maybe it is off-center... there must be a cover that goes on the front of it?
Bob
Delta's are the way!
DerStig
Post by DerStig »
crocky wrote:It suits what I have in mind as well...
The mounts for the PanelDue driver and the Duet are in the "snorkel" plus there is a cover, I forgot to link it
http://forum.seemecnc.com/download/file.php?id=11747
Outsider
Post by Outsider »
you have version 2.4
here is a copy of version 2.6 your faceplate is version 1.5
here is version 1.8
PanelDue and Duet Faceplate V2 Version 1.8.stl
(4.89 MiB) Downloaded 656 times
CRPerryJr
Post by CRPerryJr »
SeeMeCNC Rostock Max V2
Makerbot Replicator Gen 5
3D-Print
Post by 3D-Print »
Here is how I attached the Due and Duet using the mount.
http://forum.seemecnc.com/viewtopic.php ... 100#p85491
crocky
Post by crocky »
Outsider wrote:you have version 2.4
PanelDue and Duet Base for ROSTOCK Max V2 - Version 2.6.stl
here is version 1.8
Thank you..... :) and 3D Print?
Bob
Return to “Duet”
