Rostock Max V3 Locked up?
hebbster
Post by hebbster »
Completed the build a few weeks ago & still learning how to really use it, had a long print last night & forgot to come back to turn everything off. Printed from SD card using the interface & wanted to do another different print today - but now it seems to be locked up?
Only has the "SeeMeCNC RostockMAXv3 FW 20161114 Repetier v 0.92.2" on the LCD control panel & turning knob/pressing buttons works. Connects via Matter Control using usb, but still nothing changes on the the printer. Removing SD card does nothing (same response w/ & w/o card), turning off unit & back on no change.
looked at the terminal in Matter Control when connected, seems to be repeating pattern of "<-iis2dh accelerometer initializing...
<-start" but to be honest I don't know enough about what to expect to troubleshoot it. Here, I'll export the logfile maybe someone can give me some ideas what to try next??
Is there a master reboot or something I should be trying? Power off/on doesn't do anything... Thx for any ideas!!
RostockMaxV3161209probprint_log.txt
(6 KiB) Downloaded 346 times
Re: Rostock Max V3 Locked up?
Check your wiring. :D
hebbster
Post by hebbster »
geneb wrote:Check your wiring. :D
Sorry I don't get that suggestion - it might change overnight? Guessing it has 20+ printing hours on it (who knows how much on-time) & the unit wasn't moved except removing the SD card to put another image on it (previous 7+ hour print was printed from the card).
The last print it did (maybe 8 hour print, longest to date) did report "Killed" when I came in this morning, but the print was finished & came out just fine. What would I check, is there some sort of troubleshooting routine or how do I test for working components?
- Chris
Post by Mac The Knife »
Have you checked the connector at the hotend? Apparently it can work loose if you haven't made PartDaddy's clip for it.
hebbster
Post by hebbster »
Now understand, will check that in the morning when I'm back there. Saw that in the build notes thread a while ago (http://forum.seemecnc.com/viewtopic.php?f=112&t=11104) but didn't make the connection (no pun intended). Will see if that's the issue.
hebbster
Post by hebbster »
Thanks Gentlemen, that was it!
Hotend connector worked loose on one end, enough to cause the lockup error. Will be printing the clip when I have more time tomorrow night...
"wiring". :D
Glad you got it working.
