LCD Installation Guide
Here's where you can find the official (and unofficial too) things like assembly instructions etc...
The new LCD Installation Guide is available for download from:
http://www.geneb.org/rostock-max/lcd-in ... -guide.pdf
This guide covers the wiring of the panel, but not the mechanical installation. I may update the manual in the future if I update my machine with the new LCD door mount.
If you see any errors, please yell so I can get the guide updated!
Gene.
Re: LCD Installation Guide
Updated this evening to fix a column name error. (was SPI, should have been EXT2)
aehM_Key
Post by aehM_Key »
Haven't tried it yet, but thanks a lot!
You're quite welcome! Note that there _might_ be a wiring error in the guide - I built a cable harness for it last night and while the power & address lines are ok, the wires handling the rotary encoder and the reset button are wrong. I haven't had a chance to ping out the harness to see if I made a mistake in my wiring, or my description of the wiring. I'll post a note here about it either way.
Version 1.1 of the guide is posted (same link as above) and I've verified the wiring instructions are correct. I may not have seated the connectors fully as it's working great now. Go figure. :)
slausonm
Post by slausonm »
geneb wrote:Version 1.1 of the guide is posted (same link as above) and I've verified the wiring instructions are correct. I may not have seated the connectors fully as it's working great now. Go figure. :)
Have not tried the wiring yet, but this guide is so much clearer to understand. THANK YOU! Your hard work is very appreciated.
Matt
Matt, you're quite welcome! You'll enjoy the LCD, it's fun to play with.
Note that if you want to use the machine while it's disconnected from a host computer, you'll need to change a jumper on the RAMBo so that it's powered by the PC power supply and not the USB port. I seem to recall John saying something about adding that bit to the Rostock MAX wiki page on reprap.org.
zmocar
Post by zmocar »
Quick question.....
What does "100%" on the LCD start up operate or adjust?
That means that the machine is going to operate at 100% of the setting you used to slice a model. If you turn the knob clockwise, it will speed the printer up. Turning it counter-clockwise will slow it down.
daftscience
Post by daftscience »
Awesome writeup.
I had some Rainbow Ribbon cable and a couple of Crimp connectors. This made identifying the wires much easier.
jesse
Post by jesse »
It's possible to find cheaper connectors on eBay by searching "dupont connector".
johnoly99
Post by johnoly99 »
One second guys. We JUST got the RAMBo to LCD adapter PCB's in last week. Here shortly, ALL LCD's that ship with ROMAX kits will have it included in place of the RAMPS adapter. Yeah, we know, it was a PITA to wire up at first, but, being on the absolute edge, you get bruised quicker!
Thanks to os1r1s on teh reprap IRC for hacking it first, and helping with the wiki page.
Check the website shortly. The RAMBo to LCD adapter PCB board comes with all the headers needed, they aren't soldered to the PCB, but only takes a few mins. Once done, it's about as close to plug 'n play as it gets, until arduino updates their software to map all the pins!
It's going on the site tonight.
thanks again guys
cambo3d
Post by cambo3d »
johnoly99 wrote:One second guys. We JUST got the RAMBo to LCD adapter PCB's in last week. Here shortly, ALL LCD's that ship with ROMAX kits will have it included in place of the RAMPS adapter. Yeah, we know, it was a PITA to wire up at first, but, being on the absolute edge, you get bruised quicker!
thanks again guys
hey john i dont think my kit shipped yet. hopefully im getting one :)
johnoly99
Post by johnoly99 »
If it hasn't shipped yet, yes. It will come with that in place of the RAMPS connectors, and the new LCD's only come with the shorter cables. The long cables were giving many ppl problems due to them becoming an antenna for all that fun electrical noise stpeers like to give off :)
cambo3d
Post by cambo3d »
johnoly99 wrote:If it hasn't shipped yet, yes. It will come with that in place of the RAMPS connectors, and the new LCD's only come with the shorter cables. The long cables were giving many ppl problems due to them becoming an antenna for all that fun electrical noise stpeers like to give off :)
sweet, i sent you email also. :D
I just updated the PDF of the manual. It turns out that in a totally derptastic oversight, I forogot to credit os1r1s! *headdesk*
Fixed! Apologies again to os1r1s for the oversight!
Flateric
Post by Flateric »
Is there someway someone could please post some type of pic showing how this thing is mounted. I'm having a hard time visualizing just exactly how it goes. The only part of the printer that has stumped me. Perhaps because I have been building now for about 5 hours with no breaks, LOL!
Sleep, rest!? That's for when your dead right?
jesse
Post by jesse »
Flateric wrote:Is there someway someone could please post some type of pic showing how this thing is mounted. I'm having a hard time visualizing just exactly how it goes. The only part of the printer that has stumped me. Perhaps because I have been building now for about 5 hours with no breaks, LOL!
http://forum.seemecnc.com/viewtopic.php ... 5629#p5629
Mine is just laying on the table. :) I don't have a mount for it. When I have time (ha!) I should probably do something about that...
cassetti
Post by cassetti »
Is there an updated manual for how to use the new adapter kit? My kit shipped with a PCB that requires a few connectors soldered to it. I'm worried about my PCB soldering skills, but I'll give it a shot!
Sorry, no. I don't have one of the new adapter boards. Can someone who does chip in here?
tnx!
MorbidSlowBurn
Post by MorbidSlowBurn »
Bill Havens' has a pretty detailed post on the new adapter with great pictures.
http://forum.seemecnc.com/viewtopic.php ... 1346#p7176
jesse
Post by jesse »
I followed these instructions and the LCD panel is showing white boxes (full brightness, full contrast).
Tools used: Arduino 0023, RAMBo from IndieGoGo campaign (Dec. 2012), LCD screen from Jan. 2013.
I crosschecked the instructions with this page: http://reprap.org/wiki/RamboLCD
beyic
Post by beyic »
@jesse: I think the best way to find the cheap dupont connectors is that you can search it on the ebay and then find the manufacturer Part number and then just Google it and you will find the different vendors selling the same parts at different price breaks, the price also depends upon the quantity to be purchased.
Return to “Rostock MAX Official Docs”
