Repetier files for Orion missing?
LAFilament
Post by LAFilament »
I noticed that there weren't any files for Orion on Github and the instructions only refer you to the matterhackers software.
Did something change recently or am I missing it?
Thanks,
Mo
teoman
Re: Repetier files for Orion missing?
Post by teoman »
Which files are you looking for?
LAFilament
I need to reflash the firmware on the board (v 0.91 is not easily found. v 0.83 is on github)
Eric
Post by Eric »
LAFilament wrote:I need to reflash the firmware on the board (v 0.91 is not easily found. v 0.83 is on github)
You'd think it would be found under downloads->open source files->orion_delta. Perfectly reasonable place to look. But that's only old stuff.
It actually is there under downloads->open source files. The gotcha is that the default display is only popular repositories. Click on the "repositories" tab to see everything.
Or you can use downloads->all downloads->orion delta firmware for a direct link to it.
LAFilament
Thanks a bunch. Dont know why I missed that.
Return to “ORION”
