I don't know how much it took, but you need to ask yourself a question. Would the extruder be able to work if it had to push with this much pressure?tc3jg wrote:With some force I can push it through by hand Eaglezsoar
If you think it takes too much force then two things could be wrong. The hotend is not getting hot enough or the hotend is partially plugged. If you do
not have a meter with a thermocouple you need to buy one so that you know that the hotend is getting as hot as the printer says it is. One such meter
is listed here: http://www.amazon.com/AGPtek-Channel-Di ... uple+meter You start with a clean hotend that has no filament or bowden and bring it up to a set temperature then take the thermocouple lead
and put it down inside the hotend until it bottoms out inside the nozzle then you see what the thermocouple meter says the temperature is.
It's the only way to know that your temperatures are accurate. The other thing is the possibility of a plugged hotend in which case you will have to disassemble it.
Let me know!
