It's been a while since I posted anything here, so here is an update.
For the most part I'm having a great time with the Maxx.  Most Small parts print up with no problems (the Biggest is 1" x 3" x 4" tall).  But I have been having a couple of issues that are confusing me.
The first is print stoppages.  The first time it happened was trying to print out
http://www.thingiverse.com/thing:60750  It stopped about 1/2 way through.  I thought it was a USB communication fault, so I downloaded the g-code to a flash card and tried again.  This time I got the same exact fault, in the same place.  So thinking it was a corrupt file (some how) I put that job on the back burner.  This week I got the same problem again, both with USB & the Flash Card, but this time it was printing up about 4 small parts at the same time.  I was able to print those parts separately, just not together.
The other problem I have is still bed adhesion, but mostly with larger parts.  The First part was 3.5" dia and shaped like a mushroom (So I had to add supports).  The first time I had just Aquanet Pink/Extra Super Hold.
(I know, I know... you said Aquanet Purple.  The store I was at only had the pink and I didn't have time to shop around)
The supports broke free about a 1/3 in.  Then I tried The Elmer's Disappearing Purple glue stick, the support broke free before the 3rd level was printed.  Then I tried The Glue Stick with Aquanet on top,  The supports broke free on the second level.  Then I tried a part that was 4.5" dia that was flat to the printer bed, it partially broke free after printing about 1/4" (of a 5/8" tall part).  Did I mention That I had the same issue with a 6" x 6" x 1/4" part...
Material - ABS
Extruder Temp - 230°c
Bed Temp - 100°c
Right now I have 2 ideas.  Tomorrow, go buy some Kapton Tape and print onto that.  Or try out printing in PLA on these larger parts.
Edit - It's late, on New Years Eve, I'll poke around the forum more tomorrow.  I'm just frustrated, I was hoping to do a long run print job overnight.
