SIMPLE CONNECTOR FOR HOTEND WIRING COMING SOON
Jassper
Re: SIMPLE CONNECTOR FOR HOTEND WIRING COMING SOON
Post by Jassper »
TwoTone wrote:Never put tinned wires in a spring connector.
It really wasn't hard to open the spring release
Spring cage connections work well with tinned wires, unlike screw terminals, these connectors are designed for both solid, and stranded wires.
Use a push pin to open the spring works best. You can push it in and it will stay in place until you pull it out.
The MakerHive
Berd-Air Cooling Kit
The MakerHive Store
bvandiepenbos
Post by bvandiepenbos »
Actually what I use is a "straight pin" (snagged from wife's sewing stuff) works good. I think the head of a push pin would get in the way.
https://www.amazon.com/Singer-Pearlized ... words=PINS
I suppose a opened "safety pin" would work also.
Jassper
Post by Jassper »
Yes, like these, not the Thumb tac verity.
[img]https://tse1.mm.bing.net/th?id=OIP.aB0F ... g&pid=15.1[/img]
The MakerHive
The MakerHive Store
TwoTone
Post by TwoTone »
The brake spring from an XTR Trail brake works perfectly
djarmag
Post by djarmag »
On the Duet Wifi Diagram, you have the Hotend Pos/Neg going to E1 on the Duet board, that should be to E0.
Jassper
Post by Jassper »
djarmag wrote:On the Duet Wifi Diagram, you have the Hotend Pos/Neg going to E1 on the Duet board, that should be to E0.
Right you are, thanks for the catch!
The MakerHive
The MakerHive Store
Glacian22
Post by Glacian22 »
So I'm finally getting the time to install my quickclip connector, and I have a couple questions. I'm working with a much upgraded RMax V1, so I obviously don't have a premade wire harness...all of my hotend power, thermistor, hotend fan, and layer fans, all have their own pairs of wires running down to the hotend. I did buy the wire harness to populate, but the fan power has me a little confused. According to the "harness side" part of the pinout guide (http://www.tricklaser.com/media/Quick_C ... _rev5).pdf), there's only a spot labeled "fan pwm", and on the SeeMeCNC documentation (https://seemecnc.dozuki.com/Document/23/.pdf) that spot is only for fan (-). If I'm reading the circuit traces correctly, the layer fans are powered by the hotend (+) wire, right? But then on the control board side of everything (not using my original rambo anymore, it died a while back and defaulted to a RAMPS 1.4), that means the fan power header only really gets the (-) wire connected...I'm guessing that it will still correctly manage the fan even so?
With the RAMBo boards, the "-" leg is switched, the "+" is common. (someone please correct me if I'm remembering this incorrectly!"
kwilliams312
Post by kwilliams312 »
sorry to raise an old post, but are these 24v compatible?
patnap71
Post by patnap71 »
I can't get my LED ring to turn on....I know it works.
80mm ring, looks like it has a resistor already on it.
djarmag
Post by djarmag »
Anyone know if this is compatible with 24V power supply system? I'm planning to do a full 24V upgrade with the MeanWell SP-750-24 with E3D V6 24V hotend and I couldn't find specifics.
Post by Xenocrates »
djarmag wrote: Fri May 03, 2019 1:43 pm Anyone know if this is compatible with 24V power supply system? I'm planning to do a full 24V upgrade with the MeanWell SP-750-24 with E3D V6 24V hotend and I couldn't find specifics.
You may have the adjust the current limiting resistors for the LED's, but it should function otherwise.
