This one is pretty cool, if you've ever wondered where your machine comes from then watch this:
https://www.youtube.com/watch?v=ZMrcvHgBeAg
Huh. Seems like the embed code isn't working. You'll have to click through.
Tour of the SeeMeCNC factory
Re: Tour of the SeeMeCNC factory
Take the 's' out of 'https' to embed YouTubes on these forums.
I tried that, and got a white square.626Pilot wrote:Take the 's' out of 'https' to embed YouTubes on these forums.
Testing:
[youtube]http://www.youtube.com/watch?v=ZMrcvHgBeAg[/youtube]
Looks like it's a known issue, youtube changed something with the embedding. Need to update the extension or use a different one.
edit:
Better yet, remove the plugin and use the following BBcode
Then all you would have to do is click the youtube tag above and enter the ID of the video.
edit:
[youtube]{SIMPLETEXT}[/youtube]Code: Select all
<iframe width="560" height="410" src="http://www.youtube.com/embed/{SIMPLETEXT}"></iframe><br />
<a href="http://youtu.be/{SIMPLETEXT}">youtu.be/{SIMPLETEXT}</a>Code: Select all
example: [youtube]ZMrcvHgBeAg[/youtube]
