So, I didn't get the whip, for some reason I thought it would be easy enough to line up without it. It is not as easy as I had hoped.
Does anyone know what the upgrade wire relationships are for the HE280 from a stock Rostock?
8 Pin from Top to Bottom
Thermistor Signal (Positive Thermistor Wire?)
Int PIN (?) - No Idea what wire this should be
SDA( HEAT1 Black ISC2)
SLA(HEAT1 Red ISC1)
Common Ground (?) - Is this the negative Thermistor wire / FAN0 Black?
HE Switched Ground (HEAT0 Black 18 GA)
+12V Constant (HEAT0 RED 18 GA)
Part Fan ( FAN0 Red? )
Anyone know for sure?
The guide is a bit vague, it assumes you bought the whip. (I am seriously thinking of just waiting on it.)
						HE280 Wire Harness
Re: HE280 Wire Harness
I found it, had to work thru a couple of places, but modified this image from Seemecnc. If it is not clear, let me know I will update it.
Therm+ and Therm- are the now defined positive and negative terminals of the thermistor.
[img]http://i.imgur.com/S0PtXvt.jpg[/img]
No, that is exactly what I was looking for!
Where was it?
						Where was it?
- U.S. Water Rockets
From the wiring it looks like the hot end fan is no longer shut off when the hot end had cooled, and there are LEDs which are also on when the machine is on and cannot be shot off. Am I missing something?
Here: http://seemecnc.dozuki.com/Guide/Step+1 ... ssembly/45 - the link under "Files".PannDemic wrote:No, that is exactly what I was looking for!
Where was it?
As far as I know, the cold-section fan is always-on.U.S. Water Rockets wrote:From the wiring it looks like the hot end fan is no longer shut off when the hot end had cooled, and there are LEDs which are also on when the machine is on and cannot be shot off. Am I missing something?
