The Ultimate Rostock Thing Collection
Re: The Ultimate Rostock Thing Collection
Does anyone have some stls for some wrenches to adjust the cheapskates?
heres the new J head mount with fan shroud.
[img]http://i1102.photobucket.com/albums/g446/davidflowers1/Mobile%20Uploads/utf-8BSU1BRzA3OTQuanBn.jpg[/img]
Lost pla castings? see me
Applying mechanical advantage to the cheapskates would not be a good idea. Now a weighted wrench that would apply the right pressure wouldnt be a bad idea....teoman wrote:Does anyone have some stls for some wrenches to adjust the cheapskates?
wasn't it like 2 5/16" wrenches?
That is what the manual says??DavidF wrote:Applying mechanical advantage to the cheapskates would not be a good idea. Now a weighted wrench that would apply the right pressure wouldnt be a bad idea....teoman wrote:Does anyone have some stls for some wrenches to adjust the cheapskates?
That is what the manual says??[/quoteteoman wrote:DavidF wrote:Applying mechanical advantage to the cheapskates would not be a good idea. Now a weighted wrench that would apply the right pressure wouldnt be a bad idea....teoman wrote:Does anyone have some stls for some wrenches to adjust the cheapskates?
The manual shows the proper adjustment ( how they roll) in the video. Yes they say use a 7/16 wrench to do it. But that is with everything disconnected ie belts and arms.
That's why I suggested a weighted wrench to apply the proper tension. Some may be heavy handed when it comes to adjusting them without being able to slide them up and down. Personally I found it easy to tension them with just my fingers.
A weighted wrench or a torque wrench would be good.
But as the angle is not fixed maybe a rubber band mechanism would be better.
Another thing to add to the collection:
http://www.thingiverse.com/thing:1695141
It's a cartridge system for spools since I disliked the wooden arm.
I'm not sure if the V2 uses the same spool holders as my V1 that I built this for tho.
[img]http://thingiverse-production-new.s3.am ... atured.JPG[/img]
Looks like a pretty good match for the V2. I have something similar, although it came from someone else, and uses longer cones so that a single set can do more spools, and has a nice big knob on the end. But jeeze, that's a lot of spool holders. how many do you use at once?
