Air-Amplifier
Air-Amplifier
Presently working on optimizing the 3D model for the bladeless fan. Some CFD shots will be printed in coming weekend.
[youtube]http://www.youtube.com/watch?v=K5j-6TJ09D8[/youtube]
Re: Air-Amplifier
Added 3mm tangential holes to see the flow affect.The CFD in progress ..
Re: Air-Amplifier
Thanks, Due to intricacy in the geometry i have to split the air duct in 6 pieces. The first piece has been printed.
Re: Air-Amplifier
Very impressive! What application do you have in mind for this part?
Re: Air-Amplifier
Thanks, I am making Dyson Air multiplier.Jimustanguitar wrote:Very impressive! What application do you have in mind for this part?
[youtube]http://www.youtube.com/watch?v=4WNcjkZ6d0w[/youtube]
Re: Air-Amplifier
I think I can figure a way to add that to the end of my hot-end.
Cura slicer, Duet Wifi, iMac
Re: Air-Amplifier
That is a super-duper idea. You can find the STL here in the following Thingiverse link:ramai wrote:I think I can figure a way to add that to the end of my hot-end.
http://www.thingiverse.com/thing:1607868
If you need to shrink any dimension let me know.
Re: Air-Amplifier
That's what I was thinking too! Kind of a hybrid Berd-Air system...ramai wrote:I think I can figure a way to add that to the end of my hot-end.
- bvandiepenbos
Re: Air-Amplifier
interesting!
My first thought was for part cooling also.
"Berd-Air" powered of course
@Jim, so you going to have a scaled down one printed by Thursday evening so we can play with it at the MakerHive?
resin print it in one piece maybe?
Re: Air-Amplifier
Here is a little updates on the blade-less fan duct after primer application, lot of wet-sanding and finally spray paint. Check the glossiness... It just look out of injection molding machine.
Re: Air-Amplifier
Looks nice! I wish there were a way for us to see it in action. We'd need some kind of colored wind or something.
- bvandiepenbos
Re: Air-Amplifier
How about smoke from one of those electronic cigarettes?ramai wrote:Looks nice! I wish there were a way for us to see it in action. We'd need some kind of colored wind or something.
- Windshadow
Re: Air-Amplifier
or just a stick of incense
Re: Air-Amplifier
off-course smoke test as well as "Sewing Threads" hanging near the suction shall be tested to see the efficiency of the system. Presently designing 3D part for 40mm x 40mm x28mm computer fan duct attachment. Yesterday i just tested it with tap water to see the pattern of flow at the trailing edge which resembles with the results obtained from CFD.
Re: Air-Amplifier
How'd you fit it together? I have something like superglue for plastic, but the moment it touched it is perminantly attached... I'd imagine you'd want at least a few minutes of play to get everything lined up
Re: Air-Amplifier
Acetone works if it is abs.
I hear MEK or brakepad cleaner works if it is pla. But that is nasty stuff.
