Hi all from the uk, I have a rostock max v1 acrylic
mcdarren23
Post by mcdarren23 »
Having a few problems as I am a novice. Does any body have a v1 and have full settings. Thanks
Windshadow
Re: Hi all from the uk, I have a rostock max v1 acrylic
Post by Windshadow »
welcome to best 3d printer forum for deltas you will ever see this link is for the v!
http://download.seemecnc.com/rostockmax ... -Guide.pdf
as is this one
https://github.com/seemecnc/Repetier-091-ROSTOCKMAX
If i just bought a used machine like that I would take it completely apart and then reassemble following the words and music linked above that way I would both know it inside out but know I had put it together properly also you can check for any missing or badlydone things during the process
seek out threads my Hackney who uses a V1 and is one of the top experts you will find on the board.
also durring USA central time zone biz hours look at any of the SeeMeCNC main web pages for a chat button in the lower right corner of those pages click it and you will get fantastic tech support in a chat window.
welcome and enjoy
cheers
mcdarren23
thank you very uch for your help
Be very careful if you do disassemble the printer, there is a reason they are no longer sold in acrylic, if you over tighten anything it will crack.
Windshadow
Polygonhell wrote:Be very careful if you do disassemble the printer, there is a reason they are no longer sold in acrylic, if you over tighten anything it will crack.
Well spotted I failed to notice that in the title
mcdarren23
ok i will remember that thank you
