Magnet printer
TheRealRocketBurns
Magnet printer
Post by TheRealRocketBurns »
So this printer can print magnets with opposing poles on the same side. Skip to around the 2:00 mark for the video.
Article:
http://hackaday.com/2016/03/21/just-whe ... echanisms/
Video:
https://youtu.be/IANBoybVApQ
This is insanely cool :o :o :o
Re: Magnet printer
Saw that earlier. Very cool!
[youtube]http://www.youtube.com/watch?v=IANBoybVApQ[/youtube]
TheRealRocketBurns
Re: Magnet printer
I would love to see if someone designs a reprap one, maybe as an extruder you could put on to an existing printer.
Glacian22
Re: Magnet printer
Post by Glacian22 »
TheRealRocketBurns wrote:I would love to see if someone designs a reprap one, maybe as an extruder you could put on to an existing printer.
Seeing as it's a brand new technology, I'm sure it is super duper patented.
Windshadow
Re: Magnet printer
Post by Windshadow »
totally amazing refinements of magnetic theory and practice... i recall seeing examples of some of the effects done with rod neoD magnets potted in an epoxy made with iron dust but they were very simplistic compared with these
626Pilot
Re: Magnet printer
Post by 626Pilot »
Magnets are normally polarized by running huge amounts of current through them.
If I'm right, this is not a "magnetic 3D printer" so much as a Cartesian robot that places an anode and cathode on the top and bottom of the magnet, and then juices the hell out of a very small area at any one time. The direction of current flow would dictate the direction of the iron atoms. However, I would expect to see significant "bleeding" of current through the surrounding metal, blurring the "maxels."
It could be that instead of that, they're using powerful electromagnets that generate a tightly confined, very narrow and vertical EM field that passes through the magnet and orients the iron atoms as desired.
Re: Magnet printer
Could it be a resin printer with suspended magnetic particles in it, and then they just use a coil to align the particles in a particular direction for each exposure? They could do multiple "mini exposures" per layer and come up with some really wild patterns that way.
techstorage
Re: Magnet printer
Post by techstorage »
Very cool, thanks for sharing.
Re: Magnet printer
That is very cool Rocket.
TheRealRocketBurns
Re: Magnet printer
626Pilot wrote:Magnets are normally polarized by running huge amounts of current through them.
The funny thing is, I intended to printer to be interpreted as a normal 2D printer, not a 3D printer. :lol: I should have specified with this forum. The part that interests me is the speed at which it works, 5 minutes is pretty fast.
TheRealRocketBurns
Re: Magnet printer
Jimustanguitar wrote:Could it be a resin printer with suspended magnetic particles in it, and then they just use a coil to align the particles in a particular direction for each exposure? They could do multiple "mini exposures" per layer and come up with some really wild patterns that way.
Well, it appears to be affecting a piece of pre-existing metal, I do not believe it is actually depositing any material. It could be a special alloy, I'm not sure if they mention that in the video. Somewhere you can actually buy the latch demo they show, it's around 20 bucks, I may pick one up. I wonder if it has any applications for reprap?
Windshadow
Re: Magnet printer
$12 direct from them http://catalog.polymagnet.com/spring-latch-demo.html
a bit over $15 with US Mail shipping But though it says in stock it rejects an attempt to order one or two so they may have an unstated minimum order quantity.
TheRealRocketBurns
Re: Magnet printer
Thanks for the link! I emailed them to ask about that, waiting for a response.
EDIT: They may also individually make them on a per-request basis
Return to “The Lounge”
