I don’t yet own a Rostock MAX v2, but I got permission from upper management <wife> to purchase one in the next few weeks.
I have been intrigued by the use of 3D printing in making anatomic models at work. My company has provided my staff with a Makerbot. Unfortunately, I have several jobs at work, so I won’t get to actually work with the thing much. My staff will handle most of the day to day tasks. I’d really like to understand the process and technology fundamentally, and potentially understand why prints fail. I’d also like to use the printer for some basic research.
Yes – essentially, at work I’m the guy that may inadvertently ask for something impossible, and not understand why its impossible, and why its failing.
Add to that my two sons and a healthy arduino/early robotics/quadricopter hobby, and I think we’re ready to take on a project like building a Rostock MAX v2.
Goals:
1 – Understand the technology and build something from the ground up while working together.
2 – Have fun.
3 – Have decent build volume.
4 – Be reasonably accurate.
5 – Be able to print ABS and PLA.
6 – Be able to make more fun stuff when we’re done.
I could use a little advice on a couple of choices.
- I’m a little confused by the Raspberry PI and Mattercontrol Touch options. I do need to untether from my computer, as I’ll need to use it and/or take it to work without stopping a print. Do I need both – or does the OctoPI option accomplish the untethering? I also like the idea of being able to shut off a print that’s failed remotely.
The only thing about the kit that worries me is the hotend itself. Is it worth just buying a E3Dv6 and just keeping the stock hotend as a backup? (I guess I could build it all, then remove the stock and put the E3Dv6 once its all working.)
Software-wise we use a DICOM workflow with Slicer3D to generate the initial files. Meshlab can be helpful to clean things up, then send over to the Makerbot. I can do basic things with these already. However, at home we'd like to be able to design parts, cases, frames, robots, star destroyers, whatever. Any recommendations/guidance for open source 3d part design software? I'd like to be able to learn with downloaded models from the web, but the magic will start to happen when we design our own.
Especially when working with my sons, the thing must look cool. I'd like to add the Tricklaser light ring. I noticed that there may be clearance issues. On a few of the mods, I'd like to at least run the wires during assembly so I don't have to tear the whole thing apart to add something I know I'll want in the end. Anyone have comments on this particular mod, or a better suggestion for lighting the effector?
From SeeMeCNC
Rostock MAX v2 with OctoPi setup
2 additional fans for layer cooling
Extra RAMBo fuses
Tension spring spares
Several rolls of ABS, Few of PLA
From Tricklaser
From Filastruder
E3Dv6 hotend with nozzle selection
From Utilibots
Astrosyn Stepper Dampers (are the Tricklaser ones as effective?)
I'm also considering the Makerhive top plate if it makes things more modular. Is this something not too painful to install later?
Am I missing anything that I should have on hand during the assembly phase? I've seen a couple of ideas for enclosing the build area, so that will be an early project once we're up and running.
Thanks again. The community is a huge reason I've settled on the Rostock MAX v2. I look forward to joining the ranks!
D
