usb com port not working
stonewater
Post by stonewater »
my Ramboo 1.2 is working sort of.... I can print from SD card and make changes with the pot. I cannot connect with usb. latest drivers for it and arduino. seems like it wants to connect. but it times out. any way to reflash the usb driver portion of the rambo? can you relaod things of the SD card?
Tom C
MAX V1
Corvair750
V6 Hotend
Robo 3D
Flashforge creator
teoman
Re: usb com port not working
Post by teoman »
It is not a potentiometer, it is a rotary encoder. :)
Do you have the correct speed set?
stonewater
I have tried the default settings from th build manual, and worked my way around thru a few of the others, same problem regardless of speed I set. you can set it on the LCD and save to eeprom...
Tom C
MAX V1
Corvair750
V6 Hotend
Robo 3D
Flashforge creator
longshot
Post by longshot »
Not sure if this has been answered, but what version of Arduino IDE are you using? I had downgrade mine before it worked. Older boards seem to favor the 1.0.6 release rather than the 1.6.7 release. Try that out.
Return to “Rostock MAX”
