Just thought I would throw this out there. I put a single piece across the middle of my glass to test it out first using the soapy water placement. If you were careful it could be applied in two pieces with a minor seam.
http://www.banggood.com/3D-Printer-Heat ... 87679.html
Source for wide kapton tape
Re: Source for wide kapton tape
I got a roll of tape from this supplier. It's 330mm wide and covers the entire glass with some to spare.
ebay store
http://stores.ebay.com/HKSupport?_trksid=p2047675.l2563
item in the ebay store
http://www.ebay.com/itm/330mm-Heat-Resi ... 1542272064
ebay store
IMBoring25
Interesting, a 200mm strip that's about half the areal price of the 159mm strip I've been getting and a 330mm strip that's about the same as what I paid (though the cast-off percentage would be higher with it).
For those not using a single strip covering the whole bed, my approach has been a wide strip down the center and then 1" strips to fill out the edges. It makes more total seams, but anything with a dimension smaller than the width of the center strip can be printed without a seam under it.
