PEEK fan failure
Aureus
PEEK fan failure
Post by Aureus »
Hello all,
I just installed my PEEK fan and I am certain that I got the right wire pair, but when the hot end temp starts rising, the PEEK fan does nothing! :cry: I don't have any clue about what I did, if anyone can help that would be awesome!!
-Aureus
My Printers:
Orangesicle (Rostock MAX v2)
DeltaCon
Re: PEEK fan failure
Post by DeltaCon »
Do you have current on the wires? Switched + and - ? My fan wouldn't even turn backwards when I got the plus and minus switched.
Aureus
Post by Aureus »
Hi DeltaCon,
I have checked the wires and they are indeed correct, and the HEAT 1 is getting 12 v to it. I still have no idea what is wrong.
Thanks,
-Aureus
My Printers:
Post by Xenocrates »
Give the fan a manual couple of spins. If it's not smooth, either the bearing is toast, or something is interfering. Likely a string from the holder, or the holder being a bit too snug. Also, try swapping the polarity of the fan and give it another shot. If that doesn't help, then I suggest you remove it from your printer, and use a yankee'd computer PSU to test it (paper-clip shorting the green and a ground lead), and then connect a yellow and a black lead to the fan (12V+ and ground)
Aureus
Post by Aureus »
Alright, I will try that Xenocrates
-Aureus
My Printers:
Aureus
Post by Aureus »
I took the fan out of the fan shroud and it started running, so I will sand the fan shroud down and hopefully it will work.
-Aureus
My Printers:
Aureus
Post by Aureus »
Sanded the fan shroud down and it works! Thank you all for helping me!
Thanks,
-Aureus
My Printers:
