JJ has responded to the problem that Gene fixed about the LCD cables and i have responded to him
Hi JJ yes Gene saw my plea on the forum and set me straight (i had not noticed that the picture showing the inserted cables was upside down form the picture that had you mark the pin locations so while I had a t a and b- b the pin one end of the ribbon was at the wrong end of the pins….
but I do have problems my thread
http://forum.seemecnc.com/viewtopic.php?f=42&t=9406
covers them  please look at page 2
Well the bed will only take a n auto tune command for 60c not the needed 100c and it should heat to 80c in about 10 to 12 min from a room at 23c my room is at 20c as I am cheap and  i like things on the cool side..
73 C seems to be the max after an hour of heating
. So what is going on?
Three possibilities
1.  the power supply is not putting out it's rated power.... Unlikely I think but possible
2. The bed itself is defective... Also a low chance....
3. The thermistor I installed is faulty… or it is no longer in its proper position in the hole….  Ah I bet this is it. Have pulled the thermocouple used in my heat treating oven to see exactly what the bed temps are over what the thermistor is reporting
and been said this morning that the bed is too large to use autotune
the other problem is that after I attempted to print
the part  from this page 110 of the manual after I got a useable PPK fan holder printed (seen on page 2 of my build thread) after i adjust ed the end stop on the Gamma tower and switched to using paper .07mm thick from .12mm thick
the tower homed after I hit print (after I used my heat gun to careful raise the bed temp to 80 so printing would start. which was what i had to do to do the peek fan housing to start.)
Highcooley's Onyx Bed Leveling Aid is a great one to test your calibration. Highly recommended. If you can print it perfectly you've "arrived".
then it dived to a spot just between the Alpha tower and the gamma tower about 5 inches above the bed and made stuttering sounds before I turned off the printer
so I went the simple circles 6mm high from page 110
http://forum.seemecnc.com/download/file.php?id=8210
 and did a tower cal and a reset z hight  and tried to print this time it went to a spot about 4 or 5 inch above the bed again near the Alpha tower and started to air print
so i shut down the printer and restarted it and rebooted the macbook pro I am using to drive the mater control i redid the clear memory and reinstall from page 10 and 12 the “Repetier.ino”
 and redid tower cal and set for the z hight and tried the 6mm circle again and once again it went to AirPrint in the same area near the alpha tower
after it all being shut down over night I am trying to heat the bed again and once again when 80c is commanded the max it gets to is 73 then it drops to 67 and inches back to 72 or 73 a nd aoccelates between the two
the effector homed and once again started to air print the 6mm high small circle near the alpha tower even this on the MC screen it is properly seen as centered on the build plate
On Dec 28, 2015, at 11:32 AM, JJ Johnson (SeeMeCNC Support Desk) <
[email protected]> wrote:
##- Please type your reply above this line -##
Your request (118403) has been updated. To add additional comments, reply to this email.
JJ Johnson
Dec 28, 11:32 AM
If you are having problems with the display, lets first confirm that the cables are installed correctly.
What is the color of the LCD Controller board? Red or White?
If the board is White
When looking at the RAMBO board in the machine the red stripe for the ribbon cables (when attached to the LCD adapter, which is attached to the board) should be on the right hand side for both cables. Please Confirm.
The B ribbon cable should be attached to the bottom of the LCD Adapter - and on the LCD panel it is closest to the SD card reader
The A ribbon cable should be attached to the top of the LCD Adapter - and on the LCD panel it is furthest from the SD card reader
If the board is red
When looking at the RAMBO board in the machine the red stripe for the ribbon cables (when attached to the LCD adapter, which is attached to the board) should be on the left hand side for both cables. Please Confirm.
JJ
SeeMeCNC
