PID autotune fail: temp to high
I finished my build this evening and when I attempted to run the PID autotune for the hot end it climbed up to 220 and then bailed out saying the temp was too high. After searching the forums I tried raising the temp to 220 but it did the same thing after rising up to 240 this time. Im afraid to try raiding the autotune temp any higher so I am turning this over to the forum. Thanks in advance. I have a Rostock V2 without any modifications running matter control.
V2 max with the HE280 hotend
Re: PID autotune fail: temp to high
Hello friends. I seem to have forgotten the first rule of troubleshooting when dealing with anything electronic. Turn if off and turn it back on. I ran the PID auto tune this morning and it worked perfectly on the first try. On to calibrating the Z height.
Glad you got it sorted out.
The algorithm tries to determine the PID parameters but it has a built in failsafe, if the temperature gets too high then it abandons it deciding the system is not controllable.
Had you heated up the hotend before? If you start with a hot hotend sometimes it can do that.
If you are not familiar with PID control, then have a look at wikipedia. The article is short and explains the problem well.
https://en.wikipedia.org/wiki/PID_controller
Equipped with that knowledge, you can further tune the controller yourself.
Thanks Teoman, at this point in the game I am simply trying to not set myself on fire. Eventually I wil gain better understanding of this universe.
Yes, you are probably entering an unknown domain. But you will notice that most of it is/was very simple. Just need to get the hours under your belt.
There are some aspects that are still considered voodoo, that occasionally baffle even the most seasoned engineers.
I wish there was a like button for "Simply trying not to set myself on fire", lol
