The Peek fan  on my Orion appears to be sick. I would like to get a replacement 25 mm fan. What is a good quality (and quiet)  fan that has been used. Doing a search of the forum I found this: Top Motor DF122510BL-3G
But it appears to use 3 wires not 2 like the Orion. I want to simply swap it out without having to modify what I have.
Thanks
Vic
						Peek fan replacement
Re: Peek fan replacement
The third wire, (white), is for temperature reading, so all you would need to use is the black and red wires.
Great. Thanks!
I remembersome stls to fit 4mm fans on there but cannot find any.
Yesterday my fan also died. Anditwill take a while to getthe replacement.
Just FYI, the third wire on fans is for RPM, not temperature.
I guess they're yellow for temperature? Since its for reading rpms, I'm surprised someone hasn't tried using the signal for a failsafe of some kind.geneb wrote:Just FYI, the third wire on fans is for RPM, not temperature.
A lot of computer motherboards do use the RPM wire from the fan as a failsafe. I am not sure if any of the 3D firmware does it but I doubt it because everyMac The Knife wrote:I guess they're yellow for temperature? Since its for reading rpms, I'm surprised someone hasn't tried using the signal for a failsafe of some kind.geneb wrote:Just FYI, the third wire on fans is for RPM, not temperature.
fan I have seen throughout the various printers are all 2 wire.
