WHAT WITCHCRAFT IS THIS?!
MUAHAHAHAHAHAHA!
forrie
Re: WHAT WITCHCRAFT IS THIS?!
Post by forrie »
What's this.. a new stock power supply?
I could tell you, but then I'd have to make you use a Makerbot. :D
Post by Xenocrates »
If that's a 24V power supply stock, then I am very much want. Although I wish it weren't using a side panel for the plug, ETC, as I like clean lines, and also kinda planned to have a cable duct living on the two non-door sides.
Post by Mac The Knife »
The 12 volt supply works very well also. Alot better then a PC PSU. I cannibalized a powersupply for the back panel, for the power cord, and used the kits power switch to switch the mains.
KAS
Post by KAS »
Slots in the base are different from the v2.
Of course the images give away the instruction changes, specifically:
fig6.8-1 & fig18.4-5
IMBoring25
Post by IMBoring25 »
You can print covers for the LED PSUs. Designed appropriately, you can integrate them however/wherever you want. My Mendel came with one, then I designed one for a 30A upgrade and then one for a 24V upgrade
bot
Post by bot »
I wish they made 24v ATX PSUs.
*not actually a robot
Return to “The Build Zone”
