Prometheus Hot end, TL CF arms, 0.25mm, 30mm/s, verbatim blue PLA.
Was happy with how it turned out, slowly learning all the in's and out's of the Max V2.
Just a vase, because I could...
AussieBlake
- Prints-a-lot
Re: Just a vase, because I could...
A very nice vase and a great job!
How tall is that? Looks about 7 inches?
AussieBlake
- Prints-a-lot
Yea mate its around 5 inches I think....The STL file was way smaller, I had to scale it up. Going to do another LARGER one.
Do you find that the Prometheus Hot end works better than any other that you have used?
AussieBlake
- Prints-a-lot
Hi Eaglezsoar,
I had only used the stock hot end prior to upgrading to the all metal hot end. I got similar results. Essentially I upgraded so I could crank the heat a bit with some different filaments. Plus the Prometheus gets a pretty good rap.... The only issue I had was with a faulty collet and the filament would work the collet out of the top of the heatsink. Has since been rectified. I'm very happy with it, seems to hold temp a lot better than the stock hotend, very small fluctuations.
Cheers
Blake
Cheers
Blake
