I got my first print after the assembly!! I'm using ABS 1.75 filament from MatterHackers. As expected, it didn't start out all that great. After the assembly, I was itching to print something, even if it was bad, I just wanted to print!
On the left corner, you can see the mismatched corners or layers. This happens on the opposing corner as well (if you were to draw a diagonal line). But the other corners are better and don't have that stitch look.
[img]https://farm1.staticflickr.com/273/1931 ... 8661_z.jpg[/img]
You can see on the bottom is where it printed over the lift and the bad first layer. You'll also see on the above pictures that the white tip sticking out is also the part where I printed over the lift and that piece stuck out.
[img]https://farm1.staticflickr.com/496/1950 ... 425b_z.jpg[/img]
[img]https://c1.staticflickr.com/1/359/19496 ... 19a1_z.jpg[/img]
I'll mess w/ the skirt and the first layer height settings tonight to see if I can get the nozzle to plunge and abs to stick right away. But, the part actually looks decent and the layers stacked up ok...
