1.8mm filament
1.8mm filament
I picked up some cool silver filament, and it works in my printrbot, but gets jammed up in my RMX. It's 1.8mm which must be causing too much friction in the bowden tube. Any thoughts on this, or is it a lost cause?
Cura slicer, Duet Wifi, iMac
Re: 1.8mm filament
Its possible - I do have a spool of PETG that is 1.8mm and its running fine however.
Maybe you have a slight kink in your bowden or had a zip tie too tight on it at one point? Mine has a tight spot because I zip tied my bowden tube down to the umbilical at one point.
BenTheRighteous
Re: 1.8mm filament
If you think it's bowden friction that's the problem, you can oil the filament with canola oil. Works wonders.
Re: 1.8mm filament
Before you get oil in the works, just remove the bowden tube and see how the filament slides through the tube by hand. It could also be the drive wheel on the stepper motor, the diameter of the brass fittings, or the temperature that you're extruding at. I'd check all of those first. PTFE is pretty slick stuff.
