Hi there,
currently I'm working towards achieving clean prints with thin layer thicknesses. However starting at .1mm layer thickness i get a weird kind of oozing from the nozzle when it does move without extruding. This leads to a lot of overhangs and general mess I have to remove afterwards.
I was messing with filament retraction, filament retraction and re-extrusion speeds, temperature (Currently printing orange PLA at 193°C) and extrusion multiplier. So far to no avail. Greatly reducing the temperature will help but then the structural integrity of the print will suffer.
I once succeeded doing a relatively clean print at 163°C and 0.05mm layers with this filament. But continuing to print like this eventually jammed the extruder stepper mechanics from plastic powder because of the pressure needed to even extrude. The PTFE Tube joint also broke from this.
Since I'm not currently at home, i attached two IP Camera pictures i was able to download, picturing my problem.
https://i.imgur.com/1MKpomi.jpg
https://i.imgur.com/r2cHMn0.jpg
Any ideas on how to solve this?
						"Oozing" when moving without extrusion
Having a problem?  Post it here and someone will be along shortly to help
				Jump to
	- SeeMeCNC Announcments
 - ↳ General Announcments
 - ↳ SeeMeCNC crew in the wild
 - ↳ 3D Printing Contests
 - ↳ Development Topics
 - Software
 - ↳ Orca Slicer
 - ↳ SuperSlicer
 - ↳ Cura
 - ↳ Simplify3D
 - ↳ Slic3r
 - ↳ KISSlicer
 - ↳ Repetier Host
 - ↳ OctoPrint
 - ↳ Other
 - ↳ Sculptris
 - ↳ OpenSCAD
 - ↳ FreeCAD
 - ↳ Blender
 - ↳ SolidWorks
 - ↳ AutoDesk 123D
 - ↳ EMC2/LinuxCNC
 - ↳ Skeinforge
 - ↳ Mach3 Software
 - ↳ MatterControl
 - ↳ Creation Workshop
 - ↳ Fusion 360
 - General Forums
 - ↳ New Member introduction
 - ↳ The Lounge
 - ↳ Live Stream Announcments
 - ↳ Show us your machine!
 - ↳ What are YOU making?
 - ↳ General Tips 'N Tricks
 - ↳ Troubleshooting
 - ↳ Rostock MAX Official Docs
 - ↳ ORION Official Docs
 - ↳ GCode & Test Prints
 - ↳ The Build Zone
 - ↳ FAIL HAPPENS ! ! !
 - ↳ Filament
 - ↳ Test Forum
 - ↳ Members Marketplace
 - Extrusion Based Machines
 - ↳ Artemis
 - ↳ BOSSdelta 300
 - ↳ BOSSdelta 500
 - ↳ RostockMAX v4
 - ↳ RostockMAX v3.2
 - ↳ RostockMAX v3
 - ↳ ORION
 - ↳ ERIS Delta
 - ↳ Hacker Series - H2
 - ↳ Rostock MAX v2
 - ↳ Rostock MAX
 - ↳ H-1.1 3D Printers
 - ↳ H-1 3D Printers
 - ↳ Other Machines
 - ↳ RailCore
 - ↳ Scorpius™
 - ↳ Constellation
 - Regional Forums
 - ↳ Sprechen Sie Deutsch
 - ↳ Parlez-vous français
 - ↳ Hablas español
 - ↳ Australia and New Zealand
 - UV Liquid Resin Printers
 - ↳ DropLit
 - ↳ Resin Materials
 - ↳ Troubleshooting
 - ↳ Development Ideas
 - ↳ Skylight
 - Hardware Store
 - ↳ Nuts and Bolts
 - ↳ Computer Hardware
 - ↳ Mods and Upgrades
 - ↳ Heated Bed How-To's
 - Electronics
 - ↳ RAMBo
 - ↳ RAMPS
 - ↳ Azteeg X3 and X3 Pro
 - ↳ Beaglebone Black
 - ↳ Duet
 - ↳ Sanguino (lulu etc...)
 - ↳ Gen6 and variants
 - ↳ Printrboard
 - ↳ Power Supplies
 - ↳ Alligator Board
 - ↳ Other Controllers
 - ↳ OTHER Electronics
 - SeeMeEducate
 - ↳ Teachers Lounge
 - ↳ Show Your Work
 - ↳ Software Help
 - ↳ Design Help
 - ↳ Show and Tell
 - SeeMeFPV MultiRotor Forums
 - ↳ General FPV topics
 - ↳ Motors
 - ↳ ESC's
