[Solved] Printer won't turn on
- jeffhuber
I have about a year old rostock max v2 with the viotek 450W power supply. It's been working great, but went to turn it on today and nothing happens. I can't hear any fans running. How can I diagnose this issue? thanks! (i have a multimeter)
Rostock max v2 with e3d v6
- Tincho85
Re: Printer won't turn on
Unplug the PSU from the Rambo, check the power switch wiring (green and black if I recall) and try to turn it on.
If it does, then it's not the PSU. Rambo fuses maybe?
Martín S.
- jeffhuber
Hmmm no dice. Unplugged PSU from Rambo, power switch is ok. But I turn on the printer and I nothing happens in the power supply. I expect I should at least hear a fan spinning?
If you have a voltage meter you could check at the power connector where it attaches to the Rambo. If you're not getting 12v there you could have a blown fuse in the power supply. I believe the stock power supply's fan always runs when switched on.
Just obviously unplug the mains if you open up the power supply to poke around.
- Tincho85
If you are going to open the power supply, be VERY careful. The capacitors can hold a charge for long after they have been switched off (they are charged to ~320vDC).
But they are shunted by bleeder resistors which will reduce the voltage to a safe value in a minute or two.
To be sure, wait five minutes after unplugging the PSU before touching anything inside.
http://www.tomshardware.com/forum/16195 ... -dangerous
Martín S.
Thanks for the safety tip!Tincho85 wrote:If you are going to open the power supply, be VERY careful. The capacitors can hold a charge for long after they have been switched off (they are charged to ~320vDC).
- jeffhuber
thank you also for the safety tip! I took apart the power supply - and well I didn't see any issues - I concluded that it was fried since it wasnt delivering any power. thanks for the help!
