Any suggestions?
Define everything locks up.ConnorMB wrote:Hey guys. I tried emailing support and never got anything back, so i figure i might as well post here and get a bigger opinion on what is going on. Running a Rostock Max, following the guide in the offical docs to set up the software and im running windows 7 and 8 in a dual boot config. After connecting to the printer, installing the drivers and booting up repetier, I can issue 1-2 commands before everything locks up. After it locks up, i disconnect and reconnect and can not issue anything. So i unplug the USB and re-plug, and it throwing up a unknown device error. Happens in both W7 and W8. I have reset the rambo board several time, sometimes it will randomly work again and will repeat the entire process. I have tried installing/reinstalling the drivers as well.
Any suggestions?
Don't suppose you have a different PC you can try?ConnorMB wrote:Just repetier. Logging doesn't show anything as it just immediately freezes. Have to close out and i can connect but then all the commands go into waiting and it freezes up after a bit. After I disconnect the USB it throw up the malfunction USB and i cant connect to it at all anymore. Tried reseting PC, Rambo, and tried a different USB cable :/
You didn't state if you'd actually managed to successfully flash the board with the arduino tools but.ConnorMB wrote:Yes, i have tried 2-3 different USB cable to no avail, im begining to wonder if its my rambo board. I get all kinds of weird lights sometimes. I NEVER unplug anything from it while its on besides the USB from my computer. I learned the hard way a long time ago. I did contact support and pointed to this thread as well. He said listen to you, and then i guess i should go back to talk to them after ive tried all else. *shrug* for my first DIY printer, this isnt going as well as i hopedi had a replicator before this. I havn't even touched any of the other electronics once i ran everything. Just trying to get this to work for more than one command before i take on testing everything else
lmao... wow sorry, I managed to reply to the wrong thread with that one.ConnorMB wrote:Dont really need a crimping tool, need help figuring out this odd issue (at least i think its odd).
On a side note, a friend was building a reprap and stumbled upon this... "issue": http://www.youtube.com/watch?v=AHnN2CC9 ... 1A&index=5
