Another rostock max build
While i wait for my kit to arrive.
I've been researching and gathering information for my build.
What have you guys been doing for the heated build plates?
From what I gather on the forums that I've seen. People use an aluminum heat spreader on top of the heater then add boro glass on top.
Is this the way to do it to get even heat distribution?
It seems like the case from my researching. I found on another forum that heating the boro too fast will also cause the boro to flex. Adding the aluminum plate in between the heater and the boro helps to minimize this along with pid heatbed tuning of some sort.
https://groups.google.com/forum/?fromgr ... Ckwe_8vez4 and https://groups.google.com/forum/#!topic ... discussion
How many of you guys are using onyx with aluminum heat spreader and boro glass?
Just wanted to get some opinions. I have a cnc router so can cut out custom aluminum heat spreaders fairly quickly. What thickness should be used? would 1/8" thick aluminum be enough?
or do I even need an aluminum heat spreader with the onyx design? Could I just set the boro right on top of it?
Maybe the boro from seemecnc is thick enough that it wont flex?
Do I even need the boro If I'm using the aluminum heat spreader?
Re: Another rostock max build
cambo3D, the Onyx actually warps when it gets hot and that can stress glass clamped on top. It also does not distribute the heat evenly. I am now manufacturing a 1/8" aluminum heat dissipation plate for the Rostock MAX that will 1) give you VERY even temperature across the entire surface and 2) provide a very flat warp free surface. With it installed you have many options for print surface:
1) blue tape - great for PLA but I occasionally print ABS directly on it at 80°C
2) Kapton - very good for ABS. I will also be offering 12" x 12" pieces of Kapton next week when I list the heat dissipators
3) directly to the aluminum - I've been printing on aluminum with hairspray for about a year with great results.
4) with the borosilicate glass on top of the aluminum with blue tape, Kapton or hair spray
All of these are reliable methods. Since I had already ordered the borosilicate glass before I designed and started manufacturing the aluminum heat dissipator, I use it with hair spray.
Regards,
Regards,
FWIW all PCB based heaters warp when they get hot, which is why you need at least a glass sheet on top.
It's possible because of it's size that it puts additional stress on the glass. On most RepRaps the bed is actually mounted the other way up so it warps away from the glass, but it does impact the speed of heating somewhat.
I see perhaps a 10 degrees variation across the bed, which is actually not horrible.
I'm still using one of the circular glass sheets SeeMeCNC are selling with no cracking issues, though it is thicker than I would prefer, which means more thermal mass and longer to heat up.
Thanks aluminum plate it is with the optional boro glass I have coming is the plan then.
I must have read the assembly instructions that geneb wrote 3x already just to make sure I have everything I need In anticipation of my kit arrival.
I ordered another power supply for the heat bed. Ordered connectors for the rrd lcd. Saved all the links to firmware, host, slicer software. Hopefully I'm not missing anything here.
Anyone know of a good cheep temperature meter that has a thermocouple?
http://www.amazon.com/gp/product/B0012V ... UTF8&psc=1 It sells for 19.95 and comes with a K thermocouple and seems accurate.cambo3d wrote:Thanks aluminum plate it is with the optional boro glass I have coming is the plan then.
I've got the MN36 of the same brand listed above. I found the thermocouple to be very accurate. You can always double check it by putting the thermocouple in a glass of ice water. Should read 0*C or 32*F.
Word of advice though. Add some heat shrink or tape around banana plugs to wires area. My thermocouple no longer works because the wire inside broke.
So I was bored last night. I figured I would go ahead and make the lcd wiring harness, since I had already ordered the parts. (This was before I knew seemecnc guys were now including lcd adaptors.)
but anyway, I did it using the instructions without even having the machine yet. It wasn't difficult at all. I skipped the lengthy read on how to wire it with the included harness and just made my own. Took me about an hour. Here's how it looks. Probably will use the new adapters but I'll keep this as back up.
just recieved my new kit, here's a first look at the new rambo lcd adapter board.
and here are some initial unpacking photos arrived safe. More to come stay tuned...
Now you get to have the great fun of stripping tape and backing off all those laser cut parts!
moving right along, after taking the protective film off the big sheets. 99% of the laser cut parts came right out, there were some spots that needed a little extra force. no big deal. The quality looks good. No parts look skewed from my naked eye.
looks intimidating ehh....
There was only one spot in the laser cutting that was slightly off. shown here but nothing a little sanding can't fix. Didn't look like it was drawn correctly. not laser related. All of the other axle supports were good.
about an hour later, i'm officially rostock initiated. Maybe I shoulda worn gloves.
There were a couple of spots where the outline of the counter sink holes were not centered. hmmm
now to start base assembly.. whewww.. time for a dinner break.. more to come...
It looks like you are missing #68324 - the hotend spacer. Make sure you don't accidentally toss it!
Found it...Good eye, it was under the pile of discarded parts..
See, we do pay attention!
FYI, sanding the edges with a dremel gets rid of most of the burnt wood smell. My acrylic kit had a few wooden parts.
Wow! Maybe that's why my build only took a little over 8 hours! That sounds like a lot of work. I just used an old towel and wiped off the char. Worked fine, kept my hands from turning black and I didn't notice the fragrance!
More progress. I did have to lightly sand some holes out for the nuts to fit properly but not all were like that. Some fit perfectly, some holes loose.
Had to do some minor sanding to get some of the tabs to fit. Took me a few minutes to get the top of the base lined up but I got done. Definitely not designed for ease of assembly but so far no major hiccups. Moving right along with genebs assembly guide. The off center countersunk holes weren't lining up but didn't effect assembly too much, just aesthetics.
Next stepper motor installation.
These stepper motors didn't have a flat for the set screw so off to the grinder I went. Here is the result.
This will help keep the pulley anchored to the stepper motors shaft. From previous experiences in cnc machines this is a must
Next I loctited all the screws for the stepper motors and the set screws for the pulleys.
I started putting in the slot nuts for the extrusion and installed the bearings in there places. Installed the power supply.
So far still going smoothly with assembly. I then started putting together the cheapskates. This took the most time thus far because the u-joints required quite a bit of sanding to get them to spin freely. Then called it a night.
Make sure when you put the black plastic things (i forget what they are called) on the cheap skates you put the hole for the endstop screws on the same side. That way the screws will be the same for all of the cheap skates. Just cosmetic really but when you bend the tabs on the switches they will all be bent the same way.
Worst part is over, peeling the tape off of everything sucked.
You do this free hand because of your experience, do you have any tips on how to make the flats for those of us who are not so experienced?cambo3d wrote:Next stepper motor installation.
I would hate to screw up a good stepper. The whole process of touching the shaft to a grinding wheel make me nervous and at 61 I don't have
the most steady hand. Any tips would be appreciated.
You an do it with a handfile in a vice, but I would put some tape over the front and back of the motor to stop any filings getting into the bearings.Eaglezsoar wrote:You do this free hand because of your experience, do you have any tips on how to make the flats for those of us who are not so experienced?cambo3d wrote:Next stepper motor installation.
- MorbidSlowBurn
I haven't done the stepper mod myself. Is there any concern with the radial force of filing/grinding the shaft damaging the stepper?
If you do it in a vice there is none, since the thing held in the vice is the shaft.MorbidSlowBurn wrote:I haven't done the stepper mod myself. Is there any concern with the radial force of filing/grinding the shaft damaging the stepper?
having said that I doubt unless you use a lot of force the radial load is going to hurt the stepper when using a grinder. The much bigger issue is keeping any filings out of the bearings.
I haven't bothered on mine, IME as long as the screws are tight, the pulleys don't slip, and experience tells me that screws on a flat are just as likely to come loose are screws on a shaft, so I'd use loctite on either.
