Rostock max is too small...
DavidF
Post by DavidF »
So im thinking about building something bigger. Delta of course. Question is how big can one be built on the nema 17 steppers? I was thinking about something along the lines of a 24" radius and 30" z, keeping the weight down the best i could would this be possible? Ive browsed over some stuff on openbuilders.com and would be using thier 20/40 extrusion for the frame work and printing the corner brackets.
Any advice you can give me would be very welcomed.
Lost pla castings? see me
bot
Re: Rostock max is too small...
Post by bot »
So timely for this article to appear recently in my twitter feed. I eventually want something like this too.
http://3dprint.com/41871/16hertz-deta-3d-printer-stem/
Though, the pictures don't make the print envelope seem as big as they say it is...
*not actually a robot
DavidF
Post by DavidF »
bot wrote:So timely for this article to appear recently in my twitter feed. I eventually want something like this too.
Still to small, plus i woud rather build it myself. Mostly questioning the resolution of the steppers and electroincs if i did build something this size.
JFettig
Post by JFettig »
Have you thought about how large this machine will be? The arms to do a 24" diameter platform will be about 24" long, add that to the 30" build height(sine, cosine etc) and you've got a 5' tall machine.
It'll be neat though!
You could go with a board that has step/dir pins accessible(smoothie, etc) and use off-board drivers to run Nema 23 or 34 motors or even servos.
bot
Post by bot »
Now you're talking. I seriously want a part-daddy. Maybe a part-daddy junior.
Post by Mac The Knife »
I've been pondering a cartesian, with a build area of 36"x18"x12". Maybe 36"x24"x18".
DavidF
Post by DavidF »
Im kinda hung on a delta. would also like to keep things in budget and run nema 17 steppers and inexpensive electronics. Havent really put any thoughts of direction into this yet, just know what I need as far as build envelope. I could possibly tone down the x-y a bit which would keep me from pulling my hair out. But whats the fun in that?
predawnsky
Post by predawnsky »
i was just thinking about my next printer build having a build volume of around 24 x 30 and to keep the weight down i was looking at trick laser they some parts you might want to look at. you could use carbon fiber arms, and maybe more teeth on the motor
http://tricklaser.com/Trick-Trucks-for- ... TRUCKS.htm
Return to “The Build Zone”
