Plexiglass Enclosure for Rostock 2 -- Any Suggestions?
- HesDeadJim
I would like to be able to install plexiglass / acrylic walls and a hinged door around my Rostock Max 2 machine as an enclosure and I "thought" there were some printable clips/brackets that someone had designed to install such a thing but I can't seem to find them. Was I imagining things? Perhaps someone here might know where I can find what I'm looking for. Anyone heard (or imagined?) of these brackets/clips? Any assistance is always appreciated. Thanks!
Steve S. (HesDeadJim)
Omaha, Nebraska
Rostock Max v2
Omaha, Nebraska
Rostock Max v2
BenTheRighteous
Re: Plexiglass Enclosure for Rostock 2 -- Any Suggestions?
Here's one. I just built it & I like it, but I am still looking for a layer fan that won't smack into the wall... http://forum.seemecnc.com/viewtopic.php?f=42&t=7149
In fairness, you'll probably have the layer fan problem no matter which enclosure you wind up going with.
I recently had the problem of the layer fan running into my enclosure. I'm working on cutting out a section of the acrylic panel and then printing a bump out so the fan travels inside of the bump out, should be done soon. Not sure though if it's the easiest solution..BenTheRighteous wrote:Here's one. I just built it & I like it, but I am still looking for a layer fan that won't smack into the wall... http://forum.seemecnc.com/viewtopic.php?f=42&t=7149
BenTheRighteous
I guess I'm not entirely sure what you're describing, but I'd certainly like to see your approach when you can post some pictures!
I tried to design a new fan shroud that wedged the squirrel fan flat underneath the effector. It (almost) worked, but in that case you're trading one problem for another - the fan hits the binder clips instead of the polycarbonate.
I'm still noodling on if I can come up with a better solution...
- HesDeadJim
Thanks for the link! I KNEW I had seen something!
Omaha, Nebraska
Rostock Max v2
Omaha, Nebraska
Rostock Max v2
I'm super happy with the enclosure, I taped up all the holes into the build chamber to keep air from cycling and it stays up close to 40C on its own, no more cracked ABS prints!
What do you think of my version?
It´s not plexiglass but 0.8mm PET.
it is just a cylinder with some holes in it to open the casing.
The holes fit to two extended screws from the top assembly.
It`s super simple and inexpensive.
I'm currently printing JFettig's enclosure although I mostly print PLA and will have to come up with a fan design that works. ( if the one im using doesn't)
I haven't measured to see how close the fan I'm using comes, it might just work as it is. (http://forum.seemecnc.com/viewtopic.php?f=35&t=2854 )
