Damper audio comparison...
I got the Astrosyn dampers installed on White MAX, the machine built for the 2nd Edition of the Rostock MAX v2 assembly manual. Here's a short video that demonstrates the before & after change to the sound the machine makes.
Thanks for lightninjay for posting the gcode file I used.
Here's the video: http://youtu.be/OfobfmrimuI
- Captain Starfish
Re: Damper audio comparison...
Nice.
What the video, with a microphone up next to the printer, doesn't convey is what the sound is like six feet away or in the next room.
I can sit and work in the same room as the printer, and sleep in the next room without being disturbed by the noise now that the Astrosyns are installed.
I just installed some today too! My wife is very happy!
The video Gene posted certainly gives a user a reason to buy the dampers.
The difference in sound with and without the dampers was dramatic.
Good job, Gene.
Good job, Gene.
Thanks, Eagle.
The funny thing is, I only installed them to show how they were installed. The noise doesn't bother me at all. I spent most of yesterday with two un-damped machines printing in the same room with me. It was no biggie.
- lightninjay
Ha! I just got around to finding this thread!
That's too funny Gene, glad you liked my file enough to use it for your demonstration.
Here's another example, although not nearly as cool but hey....
http://youtu.be/hjvHbvPFEqM?list=UUBaX2 ... XBhJrmQPQQ
The Imperial March is *always* the right test file.
How easy were they to install? Got mine today. Presume it's just a case of slackening up the belts at the top, undo the bottom bolts holding the stepper, move the pinion further out to accomodate for the dampers, and then reinstall and tighten up?
Will be doing mine tomorrow most likely.
BenTheRighteous
In theory, that's all it takes.
Mine did not go that smoothly.
- Captain Starfish
I didnae even have to slacken off the belts, was easy peasy:
- unscrew stepper motor, winkle it out.
- push the pulley out 7mm further along the shaft, it just fits.
- reinstall on the dampers, a screwdriver can be used to loop it around the pulley again if you can't get the required angle of the dangle.
Angle of the dangle, I like it!
Cool, hopefully do that tomorrow
