I was testing a plotter attachment I created and on this particular run it crashed. The problem was the G3 Arch command. I had read that the firmware supported this command but apparantly not.
[youtube]http://www.youtube.com/watch?v=keeJKY-h ... e=youtu.be[/youtube]
I used VcarvePro CAM software to generate the gcode. I had to find a post processor that did not use Arcs.
Here is a result of the success.
[youtube]http://www.youtube.com/watch?v=V4JmNgv9 ... ow&index=2[/youtube]
Now I need to go out and experiment with the pause command so I can change pens mid stream.
My Plotter Crash
My Plotter Crash
Please feel free to vist my website at:
http://www.kronosrobotics.com/
Re: My Ploter Crash
Nicely bended rods
What current limitation do you have for the steppers?
Re: My Plotter Crash
Whatever the stock settings are. I have only made the changes outlined in the SeeMeCNC docs.
Re: My Ploter Crash
Which firmware are you using? Repetier or Marlin?
I am using marlin, as that is what is pointed to in the documentation. Other than these forums have I seen recommendations of support for any other. So from this I can only assume that the marlin firmware is the only firmware that is officially sanctioned.
Since I will be writing on my experience with the build and the operation of the machine, it is important, at least early on that I stay on the reservation whenever possible.
