GAH
continuing the calibration.  I started to do the calibration using the V2 SE assembly manual.  Hmmm, the screens don't match.  pull up the V1 manual.
{ ok, ok, I admit that I skipped over the part about updating the firmware... TWICE
or more }
The V1 calibration process - as my brain saw it...
- Home all axises - ok
   - measure from bed to nozzle - huh
  - subtract something - ???
  - touch off tip to bed and subtract something else - uhm
  - Bend over backwards & stand on your head (ok, I was a bit overwelmed)
I thought this was going to be easy.  I wonder if the new firmware is compatible with Cambo's modifications.  let's check the forum.
Found the thread about the new firmware update...
and the 9 Pages of Replies
I'm still trying to overcome the shock/confusion/hesitency and get this puppy running...  I just don't want this thing to go BOOM
EDIT - Amazing what a clear head will make.
I got an email reply from Cambo stating my fear.  That he has modified the firmware and the change "it would probably effect it".  So I'm going to keep the existing firmware.
for some strange reason the V1 leveling instructions make a lot more sense now (read - clear head)
I'm noticing a shake in the Z-Tower Skate when I move the effector.  I'm thinking I need to check the belt tensioning
