Description:
Some tabs for holding the glass on the Onyx rev. 7 heat bed on the Rostock Max v2. It MIGHT work for other revisions. PRINT WITH 100 PERCENT INFILL IF YOU WANT TO LIVE! Also, I ended up putting 4 on in the standard configuration around the "back" of the machine and then I trimmed the very tiny tabs (they are the 1mm tabs for holding the glass down) off of the front two so that I could install the glass. The parts aren't very flexible and the v1.1 with thickened extrusions are SUPER NON-FLEXIBLE so it's not possible to just drop in the glass until it clicks. The four tabs at the back hold the glass down enough, though. I think that I could probably get rid of the tabs altogether if I wanted, but I'll leave 'em.
Version: v1.1
Date: 10-31-14
Photos: (n/a)
Downloads:
Repables: http://repables.com/r/423
Bitbucket: https://bitbucket.org/redoverred/onyx-r ... s-for-rmv2
License:
This work is licensed under the Creative Commons Attribution-ShareAlike 4.0 International License. To view a copy of this license, visit http://creativecommons.org/licenses/by-sa/4.0/ or send a letter to Creative Commons, PO Box 1866, Mountain View, CA 94042, USA.
Version History:
v1.1: Thicker tabs for strength.
v1.0: Initial.
Onyx r7 Glass Tabs [v1.1 10-31-14]
- redoverred
Re: Onyx r7 Glass Tabs [v1.1 10-31-14]
Thanks for the links for the Glass Holders! They worked fine on mine.
- redoverred
Cool, I'm working on a redesign of them to hold the glass down better and give them a customizable height since I'm adding a copper plate to the mix soon to spread heat better.Eaglezsoar wrote:Thanks for the links for the Glass Holders! They worked fine on mine.
