I'm sure there's a very simple answer to this, but it eludes me...
The manual clearly states the white wire is to be pin #1 in the connector, however I don't see where it's stated which spade the white wire connects to on the switch (C or NC). Could someone please clarify? Thanks in advance.
Endstop wiring
Re: Endstop wiring
Figure 93 shows the white wire connected to the Common terminal on the switch, identified in Figure 91. That said, it's just a switch. Polarity doesn't matter in this case.
- dan
- dan
