Well... The rambo wiring went quicker and easier than I anticipated (except for the damn pin crimping! could of used another two or three set of hands for that. shoulda just soldered them in... hahaha)
Got everything hooked up and sealed up and started in on the software and calibration. Didn't take long tofigure out that the hotend wasn't working... :-\ Didn't take long to figureout that when I put the rambo in the support in the base it pulled the wires for the hotend out... perhaps I cut those a little short. No major problem. It only pulled the blackwire loose. I had that bundle zip tied, but it wasn't too hard to pull the black wire out and that gave me another 3-4 inches. I wired it back in and put everything back together. Working Hotend!
Only problem I have at the moment is the Heat bed LED won't light up... not a big deal as it's pretty dang easy to look at the LCD screen and see that, yes, the bed is above room temp. Still, this slightly annoys my OCD. hahaha I've got the rev6 Onyx. it's slightly different than the Rev5 in the manual, but I don't think I soldered or wired anything wrong... so maybe it's just a bad LED? Now that I've got it calibrated I'm hesitant to remove the bed in order to troubleshoot it. Oh well.
The only other issue I have is Repetier Host crashing every other time I try to access the EEPROM settings (also, sometimes it only shows part of the settings requiring me to cancel out and access it again, which, 50% of the time, causes a program crash). Argh, frustrating! Anyway, finally got the temps and endstops calibrated with everything showing nice and level. Loaded up the filament and the PEEK fan shroud model into SLIC3R, Loaded the ABS config and sliced the model, and went to start the job only to realize... no disappearing purple glue sticks for sticking it to the glass!!! GYAR!!! 11pm by this point so... I put down a layer of masking tape and spray it with a little bit of loctite spray adhesive (not overly optimistic that stuff is going to work.) I start the print and... nothing happens. I wait 5 minutes and the bed and nozzle temps refuse to come up. I kill the job and start it again. nothing. I try to send some manual commands. nothing. I try to disconnect the printer. "Your heating elements are still on. Want to to turn those off?" Yes. "nope." Obviously another software issue with repetier host. I finally had to kill it from the task manager. I then disconnected the usb and cycled the power on the printer. I reconnected everything and reloaded and sliced the model. This time it rehomed and started heating things up. Everything hit the correct temp and the print finally started... and instantly failed. the tape made the build platform just a hair (literally) too high and the loctite didn't stick anything. I'm sure there is an offset in the program somewhere to compensate for the added height of the tape but it was 11:30 by this point and I just said to hell with it. Pulled the tape and just tried printing on the glass. Amazingly, it stuck! for 7 layers... lmao. I didn't expect it to hold for the whole print, I just basically wanted to make sure it was actually going to lay the bead and whatnot.
Anyway, end result... It prints!!! I'll go out and get some glue today and by tonight I should have at least a couple of finished prints!
