Tinyhead wrote:EDIT:  I made a comment a few minutes ago that I could not get this to print as it was just too big.  Gotta take that back; I'm still learning.  If you have either of the farthest edges of the print directly across from a tower, you're done.  BUT, if you take a moment, you can see that you can take advantage of the delta geometry and put those farthest points close to a tower instead.  This is what I've now done and I can reach those distances fairly easily.
Ah ... there is another trick that, I am not sure if it is real or just my imagination (had not time/need to verify it yet).
This is, I think I can reach further distances if I mount my E3D hot end below the effector platform, than when it is mounted above it.
Which makes me think that the higher the layer, the further I can get in the perimeter I can get. It is easy to verify, though, not done it yet (yes, I am lazy!)
It makes sense, but, not always what makes sense is what really happens, so, until not verified, it is just a kind of myth
