Mach 4-Axis Board Configuration
Re: Mach 4-Axis Board Configuration
In my "SeeMeAdmin" post above (on top of second page), The Z and A axis dip switches should be set the same, for 1/8 stepping. X and Y are set for 16th microstepping.
~PartDaddy
SeeMeCNC Owner & Founder
Since 1996
Since 1996
mastercaster
- Noob
Yup.
Went over the settings very carefully and used the slic3r settings for 3mm,.02 yoda. A little fiddling and WOW. fantstic prints on Plexiglass with ABS.. Hard to belive the print quality. Thanks for a great product.
Only thing we need is some kind of good feed system. The machine needs a little tending cause the filiment tends to jump over each other and jam.. But with a little tending no real problems.
Alan
Alan
Below are my Motor Tuning Profiles. They turned out to be double of that of mhackney's configs. I also had to reverse the motor direction for the correct + and - direction.
Mtizle
Mtizle
You probably have your 34 Axis board configured for a different micro step than I do, that's why your steps per are doubled. I think I have mine configured for 1/8 stepping. How is yours configured?
Cheers,
Cheers,
No idea what the stepping is... is that configured on the board by the jumpers? My jumper settings came from Steve's with Seemecnc. So you think it could be set to 1/16 micro step right now?
Mtile
Mtile
Tizle, yeah, the board you looked at up in the lobby was 1/16 stepping.
Hi,
I am curious if anyone installed limit switches? Do you have photos or diagrams? Thanks!
Hello
I am new to seemecnc and I have a quick question that I hope you guys can help me with. I have had a 4 axis board for a while now and I think it may be an older one because everything looks the same except my dip switch only have 2 switches per box instead of 6 as shown in your pictures. Will this affect the jumper fix? Thanks in advance.
