grabredemeyer wrote:How's the progress on this looking? What are you doing for your linear motion? Actual linear bearings? Are you going with a belt driven system?
I am almost finished with the build for my prototype, I have all the printed parts finalized except for my hot end mount(currently working on that as we speak), I have used openSCAD to design all my printed parts as I feel it gives me the best control over dimensions and the final STLs turn out great, always nice and manifold as long as you pay attention to your code.
For my linear motion I have gone with 600mm long and 12mm wide rails, pretty much the same thing the Mini Kossel uses just longer and I found a different supplier out of China which is much cheaper and the rails are very solid and flat along the whole length the motion on them is smooth as butter! I got 3 rails with the carriages for $130 USD including shipping through FedEx.
I am not using belts to drive my axises, I'm not quite ready to reveal that part of the design just yet, but it is something that hasn't been done as far as I know anyway, all in all it is looking very promising!
It is going to use the new FSR method for the Z-probe for which I have designed and made my own little circuit to convert the signal from analog to digital and also provide sensitivity adjustment through a POT on the board, the board also has an LED that lights when the signal goes low indicating that the FSRs have been triggered. I plan to use the new Marlin firmware by Rich Cattell which has a promising auto calibration function, not just bed leveling but actual calibration where it adjusts the rod length and delta radius and such automatically based upon multiple probed points on the bed.
[img]
https://lh6.googleusercontent.com/-eE08 ... 000712.jpg[/img]  [img]
https://lh4.googleusercontent.com/-fKou ... 000713.jpg[/img]
I am using the Onyx heated bed (same as the Rostock Max), which I had ordered for my prototype but now that they are re-designing the Onyx I will have to wait and see if the new design will work with my printer or if I'm going to have to go another route for the heated bed.
I will have some pictures to post here and on the "Delta Robot 3D Printers" Google group very soon
Thanks for asking for an update!
BTW: I could still use some help with some suppliers for the parts needed by every 3d printer that will give me a decent discount for ordering in bulk assuming a successful KickStarter Campaign.
