I can't heat my hot end up today..
Repetier is reporting the hot end temperature as -20 something degrees..
That would be a broken thermistor most likely?
Does anyone know a way to test a thermistor?
I have a "J-head" on it's way to me, so at least I have an alternative, but I will need a way to mount it on the rostock max.
Broken Thermistor?
- analog_banana
Broken Thermistor?
Ho Hum...
Rostock Max MDF Kit purchased from Creative Machines UK April 2013
RAMPS 1.4
EZStrruder
SeeMeCNC Bowden Hotend V1
Onyx
Fware: Repetier 0.91
Sware: Repetier-Host V0.95D
RAMPS 1.4
EZStrruder
Onyx
Re: Broken Thermistor?
measure the thermistor with an ohmmeters, but when Repetier shows -20° then I think that the thermistor is really broken. Have you another Thermistor to test it?
look this, How i mount my J-Head http://forum.seemecnc.com/viewtopic.php ... 0&start=10
- analog_banana
Thanks - I tested the resistance.
the bed thermistor measures a healthy 100k
the hotend thermistor measures 1.9meg??
To the bin it goes!!
Failed components so far:
PSU - faulty batch
Extruder - orginal replaced by vendor on his advice.
Bowden Tube: mechanical faliure
Thermistor - failed - blown??
It was really lucky I happened to order a Jhead this morning on a total whim,
so I will have a spare thermistor soon.
PSU - faulty batch
Ho Hum...
RAMPS 1.4
EZStrruder
Onyx
RAMPS 1.4
EZStrruder
Onyx
-20 is possible... Remember that zero doesn't mean zero
**edit... I meant that a thermistor could theoretically report that temp, not that you live in a freezer!
Probably a damaged thermistor or loose wire/connection though.
Last edited by Jimustanguitar on Tue Feb 18, 2014 3:16 pm, edited 1 time in total.
There are several mounts on Thingiverse, just do a search while on Thingiverse for jhead mount rostockanalog_banana wrote:I can't heat my hot end up today..
- analog_banana
Thanks Jim,
As far as I know I've been measuring in Centigrade and looking at centigrade in Repetier.
Even accounting for the temperate British Climate, -20 is a bit outside standard room temp. range.
Especially when the bed reports +22
I checked the thermistor at the business end - the actual thermistor wire pigtails -
It's giving a really wierd resistance measurement compared to the bed thermistor.
I don't trust it!
I don't trust it!
Ho Hum...
RAMPS 1.4
EZStrruder
Onyx
RAMPS 1.4
EZStrruder
Onyx
- analog_banana
Thanks Eaglez.
Printing upgrade parts is not an option for me right now.
I've never really had much luck printing anything except test cubes, and right now I can't even extrude.
But maybe I can find someone local to print one for me..
For now I will just try and get a working thermistor in the old hotend.
Ho Hum...
RAMPS 1.4
EZStrruder
Onyx
RAMPS 1.4
EZStrruder
Onyx
