I was attempting to print Highcooley's bed levelling aid (http://www.thingiverse.com/thing:50505/) to check if my old calibration is valid for the new bed (it's not great, but workable, probably ~0.3mm out at max). When it reaches a certain point (about 130mm from the centre, near the Z tower), the nozzle starts to ascend from the heated bed rapidly. It comes back down eventually when finishing up around 180+ degrees around the circular arc, but I haven't left it long enough to see what happens after (scared of crashing into the bed). You can see it rise in the video below (sorry about lack of focus):
[youtube]http://www.youtube.com/watch?v=STMxSFOsKDU[/youtube]
The G-Code seems to have each travel still at Z=0.3 or whatever the initial layer height is set to, and it's repeatable whenever printing this same part. I've tried printing the bed leveller with a gap for a fan, and rotating this 60 degrees to avoid the trouble area, and this printed fine.
I've replicated the effect slightly with manual jogs but not to such dramatic effect. I've looked at the belts and there is not any apparent wear / stripping, as far as I can tell the sprockets on the steppers are attached well too.
Does anyone have any other ideas of what could be causing this issue? I can't think of anything that would cause such a dramatic error. When it happens all 3 towers are still moving although obviously I cannot tell which one is moving incorrectly to cause the drift upwards.
For what it's worth I'm using the old kit, with 15 tooth sprockets and 8 step microstepping. I'm using the latest Repetier from Git Hub (as of two weeks ago, first thing I tried was updating this), as far as I can tell it's correctly configured. I have installed tricklaser carbon fibre arms and am using an E3D hotend.
Any help would be much appreciated
