First mostly completed test hollow cube
Post your prints with the GCode used to help other users achieve a similar result, or get help.
replicant
Post by replicant »
So, I got my Rostock MAX assembly completed yesterday and figured I'd post up the best of my prints of the test hollow cube.
Here's my G-Code (I tried from both Cura and Slic3r, Cura was definitely the winner with algorithmic choices made, but the success came from slic3r):
; generated by Slic3r 0.9.9 on 2013-12-25 at 20:33:51
; layer_height = 0.2
; perimeters = 3
; top_solid_layers = 3
; bottom_solid_layers = 3
; fill_density = 0.2
; perimeter_speed = 30
; infill_speed = 30
; travel_speed = 200
; nozzle_diameter = 0.5
; filament_diameter = 1.694
; extrusion_multiplier = 1
; perimeters extrusion width = 0.85mm
; infill extrusion width = 1.02mm
; solid infill extrusion width = 0.85mm
; top infill extrusion width = 0.85mm
G21 ; set units to millimeters
M107
G28 ; home all axes
M104 S205
M190 S65
; G1 Z5 F5000 ; lift nozzle
G1 Z300 F3000 ; lift nozzle
M42 P6 S255 ; Turns on PEEK fan, may not be needed
G90 ; use absolute coordinates
G92 E0
M82 ; use absolute distances for extrusion
; -- G1 bits stripped out for size ---------------------------------------------------------------
G92 E0
M107
M104 S0 ; turn off temperature
M190 S0
G28 X0  ; home X axis
M84     ; disable motors
M42 P6 S0 ; turn off PEEK fan, may not be needed
; filament used = 4224.7mm (9.5cm3)
A pic of the, as mentioned, "most completed" test hollow cube:
[img]https://photos-6.dropbox.com/t/0/AACnae ... 9Yr_3UM13k[/img]
P.S. if that image doesn't show up, here's the image on dropbox: https://www.dropbox.com/s/t9sadzssp561e ... .26.03.jpg
brent
Re: First mostly completed test hollow cube
Post by brent »
Looks pretty good for your first print. Maybe some experienced users can weigh in on the issues you are facing and hopefully make your prints better.
Looks okay for a first print but more tuning obviously needs done.
Those width values you have look awfully wide. What size nozzle do you have?
Flateric
Post by Flateric »
Looks like you are running too hot to me.
Return to “GCode & Test Prints”
