Jumping optos on 4-axis board.
tom10122
Post by tom10122 »
How do i jumper the optos on the 4 axis board? on the 3 axis it shows there are only 10 optos and the correct way to jumper them , on the 4 axis there are 10 optos then 4 more after that, do i just ignore them?
dougmsbbs
Re: Jumping optos on 4-axis board.
Post by dougmsbbs »
Tom, Check out this post in the forum. This is what I followed to do mine.
http://forum.seemecnc.com/viewtopic.php?f=22&t=49#p2188
Home made Cnc, 2 CarveWright wood carving machines, Laser cutter/engraver, large format vinyl cutter, large format printer, and now a 3D Printer! Oh, and a shop full of equipment to take large expensive pieces of wood and turn them into scrap and sawdust.
tom10122
Post by tom10122 »
thanx all done now
tom10122
Post by tom10122 »
hmm, my z- axis will only go up it wont go downeven when i press the button to go down, ill double check the optos, its not my hot keys though
johnoly99
Post by johnoly99 »
tom, does your DRO on the mach screen change indicating it's supposed to be going down? If so, it's prob. a connection in the wiring issue
