Spiderweb thin ABS as nozzle leaves
McSlappy
Post by McSlappy »
Two opposite sides of a thin walled print:
[img]http://i.imgur.com/ZrxJPnG.jpg?1[/img]
[img]http://i.imgur.com/FWww2qy.jpg?1[/img]
This is the location of the nozzle leaving one side and moving over the opposite. It initially left a spider web of ultra thin strands between the two.
Thoughts on this?
Rostock Max. Repetier .80 firmware (does that seem right?). Glowing ABS filament. 230 extruder temp. 60 bed temp.
bubbasnow
Re: Spiderweb thin ABS as nozzle leaves
Post by bubbasnow »
sliced with which program?
McSlappy
Post by McSlappy »
Bah I knew I was forgetting something. Slic3r.
I need to come up with my default stats to paste into my posts...
foshon
Post by foshon »
Have you tried increasing retraction length or speed?
Purple = sarcasm
McSlappy
Post by McSlappy »
That's a good idea. I might up that.
bubbasnow
Post by bubbasnow »
it looks like that is also the start location of the loops? try randomizing the loop start location if so
McSlappy
Post by McSlappy »
Retract helped a little, there are some blobs on the location still, I'll do the randomize now.
McSlappy
Post by McSlappy »
I'm continuing this thread here since it seemed more fitting to a run of failed prints :)
http://forum.seemecnc.com/viewtopic.php?f=62&t=3944
