Arms Don't Line Up with Metal Legs
brbubba
Post by brbubba »
Just managed to recalibrate this guy to work properly and the model sizes seem ok, but all the recent stuff I've printed could have been off to begin with. Anyway, I'm at a loss as to what's happening here (Pictures Attached). At Y60 the leg lines up perfectly, at X60 it doesn't line up and at X-60 Y-60 it also doesn't line up to the post. What causes this, how do I fix it and does this affect prints? Thanks!
Good Line Up @ Y60!
Good Line Up @ Y60!
Bad Line Up @ X60!
Bad Line Up @ X60!
Bad Line Up @ X-60/Y-60 and a Hairy Leg, Agh!
int2str
Re: Arms Don't Line Up with Metal Legs
Post by int2str »
Look at your printer straight on from the LCD display side. Only the rear post (Y) is "straight" on the Y axis. The front two posts are not directly on an axis, but are 120 degrees offset. Therefore, if you send the printer to "Yxx X0", it will line up with the rear upright. But if you send it to "Y0 Xnn" it will not be inline with any other upright.
So, try these:
- Rear post (Z5...)
G0 Z5 X0 Y90 F3500
- Right post
G0 Z5 X-77.94 Y-45 F3500
- Left post
bubbasnow
Post by bubbasnow »
how big (mm) is the orion bed?
brbubba
Post by brbubba »
int2str wrote:Look at your printer straight on from the LCD display side. Only the rear post (Y) is "straight" on the Y axis. The front two posts are not directly on an axis, but are 120 degrees offset. Therefore, if you send the printer to "Yxx X0", it will line up with the rear upright. But if you send it to "Y0 Xnn" it will not be inline with any other upright.
So, try these:
- Rear post (Z5...)
G0 Z5 X0 Y90 F3500
- Right post
- Left post
I think I've been inhaling too many plastic fumes. Thanks, worked like a charm.
EDIT: I think sometimes you get so involved in looking at a problem a certain way that basic logic goes out the door... :D
Considering all Orions are properly calibrated before they're shipped, I'm kind of confused as to why you'd try to "recalibrate" it in the first place.
int2str
Post by int2str »
geneb wrote:Considering all Orions are properly calibrated before they're shipped, I'm kind of confused as to why you'd try to "recalibrate" it in the first place.
I recalibrated mine. The center was slightly too low squashing the first layer in the center. I've adjusted my PRINTER_RADIUS by 0.4.
Just because it comes plug & play doesn't mean there's nothing to gain or at least to be learned by going a bit more hands-on :)
Nylocke
Post by Nylocke »
That should have just been an endstop adjustment....
int2str
Post by int2str »
Nylocke wrote:That should have just been an endstop adjustment....
No. The center was lower than the outsides.
Nylocke
Post by Nylocke »
Ok, your weren't exactly specific, if its printing level now then good on you mate.
brbubba
Post by brbubba »
UPS beat the crud out of it when I received it, so I had to do Z height calibration and I also did calibration for each leg with the screws.
Return to “ORION”
