X,Y are reading at Max limit + but they are centered
Valmuric
Post by Valmuric »
Need help for a beginners in the set-up phase.
We are still working through the manual.
The X and Y are reading at +135 (mm?) in the repetier-host manual tab yet they are centered. We had to reverse the first two pins of each axis motor connecter to get it to move up on a G28.
What needs to be changed? Pins? Something in the arduino program?
We are soooo close...
bubbasnow
Re: X,Y are reading at Max limit + but they are centered
Post by bubbasnow »
so when you g28, it goes up then rests?
Valmuric
Post by Valmuric »
the g28 centers it but the numbers read 135
Your configuration of Repetier itself isn't correct. Look in the manual - (hint - look at how the end stops are configured in Repetier)
Valmuric
Post by Valmuric »
thank you =)
