I bought the 5.18:1 Geared Stepper Motor that I saw other people in our Forum using:
http://www.kysanelectronics.com/Product ... ordID=8318
When I try to run the motor it makes noise, but the shaft does not spin. The shaft just locks up so I cannot turn it by hand until I cut off the power to the motor. Current is set to 195.
Any ideas? Is it likely a bad motor?
Motor Makes Noise / Shaft Doesn't Spin
inventabuild
Re: Motor Makes Noise / Shaft Doesn't Spin
The most likely things are the wire order is wrong or the pins in the connector are not clicked into place.
The wire order should be Red Green Yellow Blue (technically geneb's guide's order should be fine, but I'm OCD like that when two out of three documents match up.
http://reprap.org/mediawiki/images/8/8b ... n-main.jpg
inventabuild
Thanks, got it working...
Could you tell us what you did to get it working.inventabuild wrote:Thanks, got it working...
That's how we all learn.
