Extrude3D's Unofficial Printrboard Documentation for the H-1 3D Printer.
Note: this is still a work in progress and will be published once I am finished with it completely. I have a really good work ethic so I think this will get done pretty fast (Early July to Mid August Completion)
The Current Printrboard v2:
[img]http://printrbot.com/files/2012/03/800p ... _Front.jpg[/img]
Cross-Platform Compatibility Tutorial. Works on all systems (Mac Tested)
[img]http://3.bp.blogspot.com/-vyW_M2LBSfw/T ... ux_mac.jpg[/img]
Why buy a Printrboard?: no soldering, no hassle, cross platform compatibility, SD card slot is always a plus (Makerbots have those and they are morbidly expensive), and easy to work with.
Hardware Mounting Tutorial: This will be posted once I finish my H-1 and order my Printrboard & NEMA 17's. NOT COMPLETED YET
Wiring Tutorial
Connecting the H-1's Extruder to the Printrboard:
You will need to purchase (Total is less than $3):
*http://www.mouser.com/Search/ProductDet ... 22-01-2021 Quantity: 1
*http://www.mouser.com/Search/ProductDet ... 08-50-0030 Quantity: 1
*http://www.mouser.com/Search/ProductDet ... 22-01-2021 Quantity: 6
*steps coming soon*
Connecting your PSU to the Printrboard
Brook Drumm gave us a neat video showing how to connect it, but we do not have the 'y adapter' that he shows in the video. It is called a 'hPCI-E 6-pin to 2-Molex Power Y-Adapter Power Cable'
[youtube]http://www.youtube.com/watch?v=bqF0m7xM ... e=youtu.be[/youtube]
Printrboard Wiring Diagram:
[img]http://i.imgur.com/1XtMF.png[/img]
Software Tutorial: I use a Macbook Pro i7, so we will be using the mac versions of Prontrface (http://koti.kapsi.fi/~kliment/printrun/) and Replicator G.
Step 1: Find/Design a .stl file (Thingiverse/Google Sketchup) and save it to your desktop.
Step 2: Fire up ReplicatorG and generate G-Code
Step 3: Open Prontrface and import your G-Code from ReplicatorG.
Step 4: Center all motors and heat extruder (and heated bed if you have one) for 3-4 minutes
Step 5: Click 'Print'
The print should now start on your H-1, way less steps and difficulties than MACH3. It was also easier to wire than the normal driver board.
If you would like to send a few bucks my way so I can get to buying my Printrboard, and lots of stuff that I mention on this page, do it: http://lgoptimusvrootkit.chipin.com/pri ... 3d-printer
Unofficial Printrboard Documentation [Work in Progress!]
Here's where you can find the official (and unofficial too) things like assembly instructions etc...
Return to “Rostock MAX Official Docs”
Jump to
- SeeMeCNC Announcments
- ↳ General Announcments
- ↳ SeeMeCNC crew in the wild
- ↳ 3D Printing Contests
- ↳ Development Topics
- Software
- ↳ Orca Slicer
- ↳ SuperSlicer
- ↳ Cura
- ↳ Simplify3D
- ↳ Slic3r
- ↳ KISSlicer
- ↳ Repetier Host
- ↳ OctoPrint
- ↳ Other
- ↳ Sculptris
- ↳ OpenSCAD
- ↳ FreeCAD
- ↳ Blender
- ↳ SolidWorks
- ↳ AutoDesk 123D
- ↳ EMC2/LinuxCNC
- ↳ Skeinforge
- ↳ Mach3 Software
- ↳ MatterControl
- ↳ Creation Workshop
- ↳ Fusion 360
- General Forums
- ↳ New Member introduction
- ↳ The Lounge
- ↳ Live Stream Announcments
- ↳ Show us your machine!
- ↳ What are YOU making?
- ↳ General Tips 'N Tricks
- ↳ Troubleshooting
- ↳ Rostock MAX Official Docs
- ↳ ORION Official Docs
- ↳ GCode & Test Prints
- ↳ The Build Zone
- ↳ FAIL HAPPENS ! ! !
- ↳ Filament
- ↳ Test Forum
- ↳ Members Marketplace
- Extrusion Based Machines
- ↳ Artemis
- ↳ BOSSdelta 300
- ↳ BOSSdelta 500
- ↳ RostockMAX v4
- ↳ RostockMAX v3.2
- ↳ RostockMAX v3
- ↳ ORION
- ↳ ERIS Delta
- ↳ Hacker Series - H2
- ↳ Rostock MAX v2
- ↳ Rostock MAX
- ↳ H-1.1 3D Printers
- ↳ H-1 3D Printers
- ↳ Other Machines
- ↳ RailCore
- ↳ Scorpius™
- ↳ Constellation
- Regional Forums
- ↳ Sprechen Sie Deutsch
- ↳ Parlez-vous français
- ↳ Hablas español
- ↳ Australia and New Zealand
- UV Liquid Resin Printers
- ↳ DropLit
- ↳ Resin Materials
- ↳ Troubleshooting
- ↳ Development Ideas
- ↳ Skylight
- Hardware Store
- ↳ Nuts and Bolts
- ↳ Computer Hardware
- ↳ Mods and Upgrades
- ↳ Heated Bed How-To's
- Electronics
- ↳ RAMBo
- ↳ RAMPS
- ↳ Azteeg X3 and X3 Pro
- ↳ Beaglebone Black
- ↳ Duet
- ↳ Sanguino (lulu etc...)
- ↳ Gen6 and variants
- ↳ Printrboard
- ↳ Power Supplies
- ↳ Alligator Board
- ↳ Other Controllers
- ↳ OTHER Electronics
- SeeMeEducate
- ↳ Teachers Lounge
- ↳ Show Your Work
- ↳ Software Help
- ↳ Design Help
- ↳ Show and Tell
- SeeMeFPV MultiRotor Forums
- ↳ General FPV topics
- ↳ Motors
- ↳ ESC's
